Y-Axis calibration failed (with solution)
I put my Mini+ on the bench to clean and lubricate it then ran the self test routine. During the X-Y calibration part, it would move the Y axis to the back, then to the front, pause, and then return to the previous menu showing an "X" for that test. No indication of what failed.
After a bunch of head scratching I realized that the bearings that stop the travel were not exactly centered and I measured about 2mm short of what it should be for the Y travel. Everything was still tight so I can only imagine it's always been that way.
After loosening the screws I had access to I was able to slide both bearings back to center, and things passed after that.
An error message of "too short" or something would have been helpful (Firmware 6.4.0)
Veröffentlicht : 25/05/2026 3:56 pm
