X Axis Failing Calibration Test Due to Out of Bounds
From my logs: ```[ERROR - Selftest:10] X-Axis measured length = 198.569992mm out of range <182.000000,192.000000>```
I recently built my Mini+ and have been struggling to fix this issue. Whenever I run my self-test, the X fails on the reverse, saying that it is out of bounds. I noticed there was some skipping, so I adjusted the belt, and it helped some, but there is still some skipping. For context, when I first built it, the X test passed, but it randomly started skipping, so I adjusted the belt as best as I could and was only able to improve the skipping somewhat. This affected the prints as the layers are printing offset. So I ran the calibration test, and now it is failing way out of bounds.
To sum it up:
- It passed initial test
- Started skipping causing printing major print fails
- Tried adjusting and it did not fix problem
- Ran self test again, and it now fails
- Went through troubleshooting guide: https://help.prusa3d.com/article/selftest-failed-mini-mini_112055
- Logs say it is majorly out of bounds.
Attached here is a photo of the layer and printing issues I have been having due to this. The inside layer should be completely filling the circle.
Check if the screw in the pulley on the motor axis is properly tightened, so that that the pulley is not loose.
