					                		Thermistor temperature fluctuations - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/thermistor-temperature-fluctuations/</link>
                <lastBuildDate>Thu, 16 Apr 2026 20:13:17 +0000</lastBuildDate>
                        <link>https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/thermistor-temperature-fluctuations/#post-629563</link>
                        <pubDate>Sun, 11 Dec 2022 11:10:38 +0000</pubDate>
                        <description><![CDATA[I am using originál prusa with no mods. Even ať the moment there are different temperature shifts on bed and head, looks the only real solution could be a fw temp_shift parameter(s). I&#039;ll tr...]]></description>
                        <content:encoded><![CDATA[<p style="text-align: justify">I am using originál prusa with no mods. Even ať the moment there are different temperature shifts on bed and head, looks the only real solution could be a fw temp_shift parameter(s). I'll try to write the suggestion/request into github. Thanks you. </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Robert</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/thermistor-temperature-fluctuations/#post-629563</guid>
                        <title>RE: Thermistor temperature fluctuations</title>
                        <link>https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/thermistor-temperature-fluctuations/#post-629547</link>
                        <pubDate>Sun, 11 Dec 2022 07:24:12 +0000</pubDate>
                        <description><![CDATA[Yes it are original prusa replacements. Yesterday i&#039;ve measured multiple thermistors, two new ones and 2  older onesUnsued new 1 -&gt; 131 kΩ Unsued new 2 -&gt; 126 kΩ Old 1 -&gt; 130 kΩ Old...]]></description>
                        <content:encoded><![CDATA[<p>Yes it are original prusa replacements. Yesterday i've measured multiple thermistors, two new ones and 2  older ones</p><p>Unsued new 1 -&gt; 131 kΩ <br />Unsued new 2 -&gt; 126 kΩ <br />Old 1 -&gt; 130 kΩ <br />Old 2 -&gt; 138 kΩ </p><p>All measured next to eachother at room temperature. I don't know if this 'small' differences could be a cause of the different temperatures. Maybe they also have a different curve when heating up or cooling down.</p><p>It would be great to get more tuning at printer level. If you use one printer editing the gcode isn't a big problem, but when using multiple printers it's difficult to keep track of and a lot of work. (I sync all gcode accross my printers)</p><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Sid</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/thermistor-temperature-fluctuations/#post-629547</guid>
                        <link>https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/thermistor-temperature-fluctuations/#post-629541</link>
                        <pubDate>Sun, 11 Dec 2022 06:20:55 +0000</pubDate>
                        <description><![CDATA[One possible work around can be to create a copy of the filament profile in prusaslicer and change the temperaturs]]></description>
                        <content:encoded><![CDATA[<p>One possible work around can be to create a copy of the filament profile in prusaslicer and change the temperaturs</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Zoltan</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/thermistor-temperature-fluctuations/#post-629541</guid>
                        <link>https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/thermistor-temperature-fluctuations/#post-629540</link>
                        <pubDate>Sun, 11 Dec 2022 06:18:21 +0000</pubDate>
                        <description><![CDATA[Sid, did you do a replacement by original prusa mini thermistor?]]></description>
                        <content:encoded><![CDATA[<p>Sid, did you do a replacement by original prusa mini thermistor?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/thermistor-temperature-fluctuations/#post-629540</guid>
                        <link>https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/thermistor-temperature-fluctuations/#post-629447</link>
                        <pubDate>Sat, 10 Dec 2022 05:55:09 +0000</pubDate>
                        <description><![CDATA[No unfurtunatly not, at the moment I enter them in Octoprint as an temperature offset but this has to be re-entered every time it powered off.  It works but it would be better to program it ...]]></description>
                        <content:encoded><![CDATA[<p>No unfurtunatly not, at the moment I enter them in Octoprint as an temperature offset but this has to be re-entered every time it powered off.  It works but it would be better to program it somewhere in the EEPROM so it doesn't depends on external software.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/thermistor-temperature-fluctuations/#post-629447</guid>
                        <link>https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/thermistor-temperature-fluctuations/#post-629366</link>
                        <pubDate>Fri, 09 Dec 2022 10:35:18 +0000</pubDate>
                        <description><![CDATA[The temperature shown on display is not the same as the real temperature. I therefore always need to add +5deg to the nozzle  and bed values. Is there an option to &quot;fine tune&quot; the temperatur...]]></description>
                        <content:encoded><![CDATA[<p>The temperature shown on display is not the same as the real temperature. I therefore always need to add +5deg to the nozzle  and bed values. Is there an option to "fine tune" the temperature in mimi+ firmware ?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/thermistor-temperature-fluctuations/#post-629366</guid>
                        <title>Thermistor temperature fluctuations</title>
                        <link>https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/thermistor-temperature-fluctuations/#post-628695</link>
                        <pubDate>Sun, 04 Dec 2022 07:10:44 +0000</pubDate>
                        <description><![CDATA[Hi All 😊 My Prusa Mini&#039;s have been running for hundreds of hours, but now i&#039;m getting issues on all of them. Fan&#039;s get broken, thermistors stops working and after a replacement under warrant...]]></description>
                        <content:encoded><![CDATA[<p>Hi All 😊 </p><p>My Prusa Mini's have been running for hundreds of hours, but now i'm getting issues on all of them. Fan's get broken, thermistors stops working and after a replacement under warranty (thumbs up prusa support 👍 ) it's all working again so that's great. But now the strange thing i've noticed that print profiles i've been using several years now, are not consistent anymore. And I didn't understand it, it took me a really lot of time, but now I think i'm getting close, at least for a part of it.</p><p>On the printers where i've changed the thermistor I got a lot of stringing en blobs. And after a lot of cleaning and changing PFTE tubes, etc etc. I found out that it was as simple as turning down time hotend temperature by 10 degrees. To be sure it was the new thermistor i've moved it to a printer without this issue and indeed after replacement it also suffered the same issue. Reconnecting the old thermistor solved the problem.</p><p>Now I know this i can tune the temperature on the specific printers, but <strong>is there a way to setup the printer that it always retracts 10 degrees of the GCODE temperatur</strong>e?</p><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/thermistor-temperature-fluctuations/#post-628695</guid>
