Stupid simple problem with folders
Andomor
(@andomor)
Hello Prusa
Can you fix/edit the problem/situation with Prusa mini
If i got lets say folder1>then enter to next folder inside>folder2>again inside =folder3>(and in that folder 10 files some stl with similar name or version of that file) but im not sure which one exactly print.. we can select and see little picture on screen .. this is great ofcors . But if we select wrong file and we wanna change it. We press back ... and then ... problem / stress appear  need all procedure from beggin .. go folder 1 . then 2.. then 3..
Need to back to all that folders again
Imagine somebody got big Pendrive with a loooot folder .etc
or a lot demo/multiversion of same file.
Opublikowany : 12/10/2020 11:38 am
RE: Stupid simple problem with folders
Hi DJ,
the best way to get ideas to the Prusa developers, is to raise the matter on the Prusa Github page for the product
Opublikowany : 12/10/2020 11:58 am
Zoltan
(@zoltan)
Member Moderator
Hi @djandomor
is not that easy to keep happy everyone under all circumstances. To stop printing can have different reasons  -
1. printed object is not sticking - you have to go for first layer calibration, sheet cleanint etc.
2. you are printing a wrong file - is the correct one in the same folder or somewhere else?
3. you just stopped because of blob or other issue - you have to go to remedy - first thing you do -switch of the printer
4. any other reason ...
- and the printer is not capable to guess wich one happened .
So the printer goes to the Home page an then you decide what next.
Should you have any idea how to solve all possible reasons, with one solution,  let us know.
Opublikowany : 12/10/2020 1:59 pm
Andomor
(@andomor)
@zoltan
Im not talking in any kind about printing .. o.O
But .. selecting file in LCD screen
Opublikowany : 12/10/2020 3:22 pm
Zoltan
(@zoltan)
Member Moderator
What FW do you use?
Opublikowany : 12/10/2020 3:27 pm
Zoltan
(@zoltan)
Member Moderator
Posted by: @djandomor
@zoltan
sorry I misunderstood your question, the issue of returning from file (not) to be printed back to the same position is solved in 4.2 and higher - returning to the same file in the same folder.
That´s why I was asking which FW version do you use.
Opublikowany : 12/10/2020 3:56 pm
Andomor
(@andomor)
@zoltan
15 min to finish print.. and i will check
Opublikowany : 12/10/2020 4:28 pm
Andomor
(@andomor)
aff...
4.0.4 😛
damm it
MK3S all the time tell me when i try print somethink = hey..you can update .. check bla bla
I will update 🙂
update done
i got even my language.. and "back" buttom work
thanks for advice 🙂
This post was modified 6 years temu by Andomor
Opublikowany : 12/10/2020 5:00 pm
