					                		Stuck on booting screen following Firmware upgrade - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/stuck-on-booting-screen-following-firmware-upgrade/</link>
                <lastBuildDate>Sat, 07 Mar 2026 11:25:21 +0000</lastBuildDate>
                        <title>RE: Stuck on booting screen following Firmware upgrade</title>
                        <link>https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/stuck-on-booting-screen-following-firmware-upgrade/#post-754810</link>
                        <pubDate>Fri, 20 Jun 2025 08:01:26 +0000</pubDate>
                        <description><![CDATA[Solved! I found a random redit post that said to put USB in, press the reset button and then double press the knob. This might be common knowledge, but not to a rookie like me! This forced i...]]></description>
                        <content:encoded><![CDATA[<p>Solved! I found a random redit post that said to put USB in, press the reset button and then double press the knob. This might be common knowledge, but not to a rookie like me! This forced it to flash. I was able to flash it using an older version of the firmware.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>WoodshedElk</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/stuck-on-booting-screen-following-firmware-upgrade/#post-754810</guid>
                        <title>Stuck on booting screen following Firmware upgrade</title>
                        <link>https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/stuck-on-booting-screen-following-firmware-upgrade/#post-754807</link>
                        <pubDate>Fri, 20 Jun 2025 07:25:05 +0000</pubDate>
                        <description><![CDATA[Hi.I just tried to update firmware on a Mini Original to the lasted version (Firmware 6.2.4).When I boot it goes through the bootloader verify screen, then this screen appears and it goes no...]]></description>
                        <content:encoded><![CDATA[<p>Hi.</p><p>I just tried to update firmware on a Mini Original to the lasted version (Firmware 6.2.4).</p><p>When I boot it goes through the bootloader verify screen, then this screen appears and it goes no further. </p><p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/06/cb86585b-prusa-mini-stuck.png"><img class="size-medium wp-image-177947" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/06/cb86585b-prusa-mini-stuck-405x500.png" alt="" width="405" height="500" /></a> </p><p>Note that the orange bars on this screen do not move or load and then pause. Rather this is how the screen looks from the moment it appears.</p><p>Any ideas would be much appreciated. </p><p> </p><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/stuck-on-booting-screen-following-firmware-upgrade/#post-754807</guid>
