Slight filament grinding
Octo
 Octo
(@octo)
Hey,
so I got my Mini for about a week now and noticed my filament is slightly grinded after unloading it. I can feel the surface has some minor dents in it where the extruder grabbed it.
So far, prints are looking nice. Typically I would say never change a running system, but am I running into problems with this and should loosen the extruder tension screw?
BTW, is there a good overview of all the adjustment screws of the mini? Got an assembled one and therefore I am not 100% sure if I identified the correct screw for extruder tension. I was surprised I couldn't find a prusa knowledge base page about it. But maybe I was blind.
Octo
Napsal : 21/04/2021 7:49 am
RE: Slight filament grinding
Some teeth marks are normal. However, the Mini extruder has a propensity for grinding filament if not properly set up. To find the screw to adjust the tension, see Step 44 in the Mini kit assembly manual: https://help.prusa3d.com/en/guide/3-x-axis-extruder-assembly_199519
I’ve found the Mini's original extruder to be too sensitive to the tension on the extruder idler screw for my taste. I ended up replacing it with a Trianglelabs dual drive extruder (a Bondtech clone), and never had any issues again, with more than two dozens filament types and brands.
Napsal : 21/04/2021 11:06 am
Octo
 Octo
(@octo)
Thanks for your answer. When you say some marks are normal, I will leave it like this, since it works fine for now.
Will think about another extruder if I run into problems.
Napsal : 21/04/2021 2:11 pm
You can always open the extruder and check for filament residue and as needed loosen the idler screw a bit
Napsal : 21/04/2021 2:42 pm
