        Seam gap with while using 0.8 nozzle
Hello,
I'm using a 0.8mm nozzle with PLA, it works great appart from the seam which create a big gap. It doesn't do it fot the internal shape, which makes me think it's a problem of parameter rather than hardware limitation...
It doesn't do it with the vase mode... but I need to use nomal mode with this one.
Is there a parameters I can change to solve this issue?
Also I notice that flow rate by default is set to 95, is there areason for that? I tried putting 100 but it doesn't change the thing
                            Opublikowany : 03/09/2023 2:02 pm
