Ratling y-axis
Odin
 Odin
(@odin-2)
Ratling y-axis
lGood evening.
I have a ratling noise on my y-axis.
I think it began when I tightened the y-axis belt in combination with the textured sheet, I have used the prusa belt tension meter end it is within limits on the lower end.
I have search the web and this forum and many have encountered this issue but I cannot find a solution.
Is there anybody here that have made a connection between the belt tension?
I attached a sound clip of the noise.
Besides that the printer is amazing so far 🙂
Best regards
prusa-rassel
This topic was modified 3 years ago 2 times by Odin
Posted : 16/11/2021 5:52 pm
Odin
 Odin
(@odin-2)
RE: Ratling y-axis
I posted this in the wrong forum
I have a mk3s+ and posted this in wrong forum
How do I move it to the correct forum?
Sorry!!
Posted : 16/11/2021 6:45 pm
BogdanH
(@bogdanh)
RE: Ratling y-axis
Admins will take care of that (moving to right place).
About noises from Y movement... it indeed sounds weird, but is impossible to guess the cause for that. Maybe you post short video, so we can see what the bed is doing while making that sound.
[Mini+] [MK3S+BEAR]
Posted : 16/11/2021 7:47 pm
