Random Under-Extrusion Issue on Prusa Mini+
Mike
 Mike
(@mike-49)
Hello everyone,
I have an issue with my Prusa Mini+: some layers print well, but sometimes I get under-extrusion, as if the filament isn’t coming out properly.
I’ve already tried several things:
Replacing the Z-axis bearings (thinking the issue was related), but it didn’t help.
Cleaning the nozzle, the extruder gears, etc., but no improvement.
I also noticed that the extruder and Z-axis motors feel hotter than the others. Is this normal? How can I test the motors to check if they are working correctly? Are the stepper drivers replaceable on this board, or are they soldered/non-replaceable?
Honestly, I’m a bit lost and would appreciate any advice! Thanks in advance for your help.
Posted : 23/03/2025 6:29 pm
Josh
 Josh
(@josh-13)
I just started having the same issue, in particular on first layer.  I do the first layer calibration and get a great layer, then go to print basic squares and they come out under extruded.  Replaced filament, cleaned nozzle/clogs, all the usual mechanical issues and can't find anything.  Just updated firmware and that didn't help.
Looking forward to some insights!
This post was modified 12 months ago by Josh
Posted : 23/03/2025 9:11 pm
