Prusa Mini: stops extruding, starts clicking
Seite 2 / 2
HU3E
 HU3E
(@hu3e)
RE: Prusa Mini: stops extruding, starts clicking
@daryl-2
I’ve done those thing already and still no luck. Im honestly out of options at this point I’ve litterly trying everything. cleaning extruder, replacing nozzle, raising the heat break, raising temperatures, and loosening in tightening the tension and still nothing 😤. Im open to ANY advice.
Veröffentlicht : 31/03/2021 4:09 am
MadCyborg
(@madcyborg)
Posted by: @hu3e
I'd check these 2 things:
1) Does the filament run smoothly through its path?
-loosen the extruder tension completely
-remove the nozzle
-now you should be able to move the filament relatively easily by hand through the system
-if not, find the problem
2) Does the extruder pull with reasonable force?
-set the tension according to the guide (iirc screw flush with the housing, when no filament loaded)
-remove the bowden tube on the extruder exit
-now use manuall controlls to pull some filament
-check if it pulls with enough force
-enough = quite some more than you needed in step 1)  (to push the filament without nozzle)
-if it doesn't, then there's a problem with the extruder
(Especially for the second step: Find, understand and use the g-code to enable cold extrusions.)
Diese r Beitrag wurde geändert Vor 5 years von MadCyborg
Veröffentlicht : 31/03/2021 8:02 am
Dario
(@dario-4)
@hu3e
Sorry you're having issues!  I have found Prusa chat support helpful when things get frustrating.  If you go to the e-shop, you'll see the "chat now" window.
Veröffentlicht : 31/03/2021 1:50 pm
HU3E
 HU3E
(@hu3e)
@daryl-2
Thanks.
Veröffentlicht : 01/04/2021 5:07 am
HU3E
 HU3E
(@hu3e)
@madcyborg
Thanks🙏 Ill let you know if it worked.
Veröffentlicht : 01/04/2021 5:10 am
HU3E
 HU3E
(@hu3e)
  • This is what all my prints look like and i really need some advice on was too do.
Veröffentlicht : 05/04/2021 5:29 am
Mitglied
Sounds like a jam.  I often have to do a cold pull.
Veröffentlicht : 05/04/2021 8:58 am
BeeMac
(@beemac)
@hu3e
The SuperPinda cleared up this problem for me.  The other thing was making sure the extruder was clean and had a good grip on the filament
Veröffentlicht : 05/04/2021 12:53 pm
HU3E
 HU3E
(@hu3e)
@beemac
I dont think thats the problem because the extruder us actually grinding the filament.
Veröffentlicht : 07/04/2021 11:08 pm
Carlos
(@carlos-6)
I had massive problems with clicking and lack of material in the nozzle. I checked everything and finally it worked by using another filament. The one that did not work was PLA original from Prusa, only a couple of months old.
I will try if with a higher temperature it works, but I lost all my patience and time. Very annonying this issue.
Veröffentlicht : 15/12/2021 1:52 pm
mattberns
(@mattberns)
Hi, sorry to be the necromancer and raise this thread from the dead.
My problem was my extruder pulley was clogged with debris, causing it to not grab onto filament correctly, as well as the idler not being screwed in properly.
Solution: By cleaning the extruder pulley and pushing in my idler completely and making the screw flush with the plastic, the clicking noise and underextrusion have gone away.
Guides to both:
https://help.prusa3d.com/guide/how-to-access-and-clean-the-extruder-pulley-mini_126457
https://help.prusa3d.com/article/idler-screw-tension_177367
Veröffentlicht : 27/08/2022 7:38 pm
Seite 2 / 2
