Prusa Mini Rebooting at same place every print
I am trying to print a box using my Prusa Mini+, but the printer reboots every time at the exact same spot on the first layer, which stops the print. The printer goes through the normal start-up procedure on the screen and carries out the fan test.
I've had it happen three times in a row, using both OctoPrint and printing direct from USB. I've attached photos showing the spot that the print gets to when printer reboots.
I'm using firmware 4.4.0Beta and PrusaSlicer 2.5.0. Any suggestions what might be causing this behaviour?
RE: Prusa Mini Rebooting at same place every print
Short in one of the wires? I'd try wiggling all wires to the hotend to see if I can induce a reset.
It doesn't seem to have an issue with any other print, and I can't force a reset by moving any wires, or by moving the axes to the point where the file always causes a reset.
