Prusa Mini on 4.3.2 is crashing, when Octoprint connects and the printer is in a sub menu.
one can easily crash the Prusa Mini, when the printer is still in a sub menu, like filament change and someone tries to connect via usb serial to the printer. The printer just gives up and is crashing. Any idea why?
Thanks a lot and regards
Olaf
Have you tried:
Have you tried:
- Factory reset
- Downgrade of the firmware
Recreatable with ease!
Yep I can recreate this easily.
4.3.1, 4.3.2, and 4.3.3-RC all will crash.
Noooooooooo
I was in the process of updating my printers....
RE: Odd
Odd, I am not having this issue. I wonder if it is an issue of upgrading from your firmware version?
I can has crasheded!
Yeah it's weird and odd
Go to printer, disconnect, say yes.
Go to filament, unload, load, what have you, stay in unload/load menu (as an example, other sub menus can create same issue)
Go to Octoprint and connect.
and you might go boom
So now I am in the habit of making sure I'm back on the main screen and never go boom as this is better than the random blue screen and loud beeeeeeeep
