Prusa Mini+ noise when printing and Z-leveing
magarto
(@magarto)
I own an Original Prusa Mini+ but recently it has a bad noise when printing in several areas of the bed and Z-axis leveling. In the video you can hear it.
Z first layer is ok (I know it sounds like to close).
I replaced the extruder to a BMG clone (FYSETC) and also the heatbreak to a Bondtech clone (Trianglelab), but using the original ones it doesn't help.
Also, I have clogs after some time but heatbreak and nozzle are tighten and no filament is on the heatblock.
I cannot find the reason of these problems.
https://forum.prusa3d.com/wp-content/uploads/2021/01/video_2021-01-09_20-46-12-1.mp4
Thanks in advance
This topic was modified 5 years temu 3 times by magarto
Opublikowany : 09/01/2021 8:35 pm
magarto
(@magarto)
RE: Prusa Mini+ noise when printing and Z-leveing
I forgot to add (cannot edit it) that the noise was reduced screwing the bed leveling screws, but there is noise when printing in several areas of the bed and when rising Z (I will try reducing maximum Z raise to 10 mm/s)
This post was modified 5 years temu 2 times by magarto
Opublikowany : 09/01/2021 8:43 pm
