Prusa Mini + Bondtech extruder estep issue
Hello ,
having issues with my mini after installing bondtech extruder. Currently have another Prusa mini
+ running but the firmware and bootloader were older versions. I cannot get to the esteps section under HW setup or Hardware with new firmware. i would prefer to not rewire and change in g code. Thank you in advance.
RE: Prusa Mini + Bondtech extruder estep issue
Away from home so I can't test with my Minis if things have changed with recent firmware but are you saying that the instructions by Bondtech don't work anymore ?
When using firmware 4.3.3 or later, proceed this way to adjust the e-steps value and reverse extruder direction:
go to LCD Menu, enter option Settings, scroll down to highlight HW Setup then long-press the knob. Similarly to the MK3S+, a new “Experimental” submenu will appear on the screen.
