Prusa Connect no longer works after update
AZ_TIM
(@az_tim)
Before the latest firmware update, Prusa Connect worked fine. Now it just never connects, the status bar on the browser stops after about a third.
I've verified the IP address on the MINI - I assign a static IP so I can always connect to it.
anybody else have a problem after the update?
I'm not a mad scientist, I'm an angry engineer in training.
Posted : 26/03/2021 5:17 pm
AZ_TIM
(@az_tim)
RE: Prusa Connect no longer works after update
was able to ping it, port scan shows only port 80 (http) as being open.
Posted : 26/03/2021 5:38 pm
AZ_TIM
(@az_tim)
Git shows a reported problem with Safari, and slowness with Chrome. I’ll try Chrome and see if it will eventually load or not.
This post was modified 5 years ago by AZ_TIM
Posted : 28/03/2021 1:58 pm
pidra
(@pidra)
@az_tim
firefox too
Posted : 28/03/2021 6:48 pm
AZ_TIM
(@az_tim)
From what I've read, there's an issue with some of the packets arriving out of synch and not getting re-transmitted properly. (I could be summarizing incorrectly though)
I'm sure they'll take a look at their HTTP logic and fix it. Could be an issue with the TCP/IP driver or simply a race / timing issue with how they update the data on the port.
Posted : 28/03/2021 7:16 pm
Oxygen
(@oxygen)
with 4.3.1 I can still connect but have to set the timeout for the REST interface to 45 seconds for it to work...
Stock MK4S
Posted : 29/03/2021 6:32 am
