					                		Problems with z-axis test - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/problems-with-z-axis-test/</link>
                <lastBuildDate>Mon, 13 Apr 2026 02:31:57 +0000</lastBuildDate>
                        <title>RE: Problems with z-axis test</title>
                        <link>https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/problems-with-z-axis-test/#post-766515</link>
                        <pubDate>Wed, 08 Oct 2025 10:32:09 +0000</pubDate>
                        <description><![CDATA[its simple to fix Z-Axis ( normally printer got 185 for it) skip wizard go setting push the button wait 3sec go experimental menu and change z-axis to 191 and save it and you got problem sol...]]></description>
                        <content:encoded><![CDATA[<p>its simple to fix Z-Axis ( normally printer got 185 for it) skip wizard go setting push the button wait 3sec go experimental menu and change z-axis to 191 and save it and you got problem solved </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Kenyiro34</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/problems-with-z-axis-test/#post-766515</guid>
                        <link>https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/problems-with-z-axis-test/#post-764637</link>
                        <pubDate>Tue, 16 Sep 2025 22:19:24 +0000</pubDate>
                        <description><![CDATA[Answered on my thread with the same issue:]]></description>
                        <content:encoded><![CDATA[<p>Answered on my thread with the same issue: https://forum.prusa3d.com/forum/postid/764597/</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Win J.</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/problems-with-z-axis-test/#post-764637</guid>
                        <title>Problems with z-axis test</title>
                        <link>https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/problems-with-z-axis-test/#post-763040</link>
                        <pubDate>Mon, 01 Sep 2025 21:00:25 +0000</pubDate>
                        <description><![CDATA[Hello,i have trouble to calibrate the z-axis of the mini+. meanwhile i re-installed the firmware, i checked and lubricated all axes and the shaft. X- and Y- axis calibration works well. alwa...]]></description>
                        <content:encoded><![CDATA[<p>Hello,</p><p>i have trouble to calibrate the z-axis of the mini+. meanwhile i re-installed the firmware, i checked and lubricated all axes and the shaft. X- and Y- axis calibration works well. always the z-axis calibration fails. i adjusted the PINDA sensor 2 times, i also checked the sensor itself, it works. </p><p>The print head moves up and down as expected, the calibration seems to work well. finally it is always declared as "not successful"</p><p>Any ideas what could be the reason for the problem? </p><p> </p><p>Thank you!</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Jannes</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/problems-with-z-axis-test/#post-763040</guid>
