Printing with PCTG on Mini+
Prusaslicer configs cover PCTG filaments but there does not seem to be an option on the 'load filament' for PCTG on the printer itself.
I used the PC option to load the filament as it seems to be a similar temperature range. It loaded okay you do get a warning when actually starting to print that the incorrect filament is loaded.
Can you advise if there is a config that loaded the PCTG option to the mini+? Currently using 6.0.3.
Napsal : 21/08/2024 2:26 pm
Make a copy of your PCTG filament profile and change the filament type to PC, leaving everything else the same. This is what is written in the gcode and checked upon load.
This post was modified před 1 year by bmorgenthaler
MINI+ with FW:4.3.3, Bondtech IFS Extruder, drilled out PC4-M8 couplers, 1 piece Capricorn bowden.
Napsal : 23/08/2024 1:16 am
Topic starter
answered:
RE: Printing with PCTG on Mini+
Thanks. I'll give it a try.
Napsal : 25/08/2024 10:39 am
