					                		PLA glued to hotend - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/pla-glued-to-hotend/</link>
                <lastBuildDate>Sun, 07 Jun 2026 22:28:04 +0000</lastBuildDate>
                        <title>RE: PLA glued to hotend</title>
                        <link>https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/pla-glued-to-hotend/#post-621682</link>
                        <pubDate>Wed, 28 Sep 2022 10:26:29 +0000</pubDate>
                        <description><![CDATA[Heat it up and try to remove it with tweezers.  Be careful, it will be very hot.  You also might have a leak.]]></description>
                        <content:encoded><![CDATA[<p>Heat it up and try to remove it with tweezers.  Be careful, it will be very hot.  </p><p>You also might have a leak.  </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>cwbullet</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/pla-glued-to-hotend/#post-621682</guid>
                        <title>PLA glued to hotend</title>
                        <link>https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/pla-glued-to-hotend/#post-621628</link>
                        <pubDate>Tue, 27 Sep 2022 17:32:10 +0000</pubDate>
                        <description><![CDATA[Dear all,After last night&#039;s print the PLA was glued to the hotend. Not sure how this could happen. I was able to get rid of the PLA below the hotend with the nozzle set to 260 degrees. Unfor...]]></description>
                        <content:encoded><![CDATA[<p>Dear all,</p><p>After last night's print the PLA was glued to the hotend. Not sure how this could happen. I was able to get rid of the PLA below the hotend with the nozzle set to 260 degrees. Unfortunately the PLA above the nozzle is strongly glued to the hotend, I can't detach it (Please see picture below).</p><p><a href="https://forum.prusa3d.com/wp-content/uploads/2022/09/IMG_2718.jpg"><img class="alignnone size-large wp-image-145523" src="https://forum.prusa3d.com/wp-content/uploads/2022/09/IMG_2718-1024x768.jpg" alt="" width="1024" height="768" /></a></p><p>I couldn't find a similar case on this forum unfortunately? Does anyone have experience with this case and how to detach the PLA?</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>magro</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/pla-glued-to-hotend/#post-621628</guid>
