OctoPi - Mini - problem on disconnection
Michal Bartak
(@michal-bartak)
Hello all, my first post over here.
You cannot imagine how hard is to phrase the problem related to disconnecting being distinctive enough to other disconnection problems found in Internet 😉
My connection is rock stable and never failed so far.
I found however, when I disconnect from the printer using OctoPrint GUI, Mini still displays that it remains controlled by serial port (showing OctoPrint logo).
Not big deal, just inconsistence. Maybe it prevents from turn the printer into standby mode.
Just would be glad to know what is responsible for such behaviour: HW, Mini’s fw, OctoPrint?
With regards.
This topic was modified 4 years temu by Michal Bartak
Opublikowany : 11/07/2021 11:07 pm
RE: OctoPi - Mini - problem on disconnection
I have had the same issue on occasion.  I just turn the printer off and on again.
Opublikowany : 12/07/2021 1:12 am
Michal Bartak
(@michal-bartak)
Actually if I'm next to printer, I can use printer's menu to disconnect. But when I'm not, I can remotely disconnect Octoprint from the printer, but it doesn't turn into the printer 'knows' about that fact.
This post was modified 4 years temu by Michal Bartak
Opublikowany : 12/07/2021 9:15 pm
