        M Code for Triggering Bed Leveling?
I have modified my new Mini with a Bondtech Heat-break and their Dual Extruder. The new extruder requires a M92 E415 as the first command in the printable G-code in order to keep the extrusion correct. I have put that command in the Custom G-Code/Start G-code in the PrusaSlicer 2.2.0 and it works fine. However, I have a couple of G-code files that were sliced without the M92 and print without first doing the bed leveling routine.
What G-code can I insert in the file to cause it to do the bed leveling before it starts the print?
(BTW, once I did the Bondtech mods the Mini prints without filament jams. I highly recommend them.)
S//
                            Postato : 13/05/2020 6:15 pm
