Loud noise when unloading, doesn't unload
thealanberman
(@thealanberman)
Just today the extruder motor started making this noise anytime it needs to go in reverse (unloading).
No visible jam inside the housing. (see video)
Since unload wasn't working I've managed to pull out the filament by force.
Since unloading the filament I've tried running a few "unload" commands and it even makes this noise without any filament at all, so I'm pretty certain it's not the sound of "grinding filament".
Any suggestions for other things to check would be great.
Napsal : 28/10/2021 3:21 am
thealanberman
(@thealanberman)
Video link
Not sure why my embedded video didn't work above, here's the link --
Napsal : 28/10/2021 6:57 pm
MicDG
(@micdg)
RE: Loud noise when unloading, doesn't unload
Hello, I have the same problem. Did you manage to fix it by any chance?
Greetings,
Michele
Napsal : 13/12/2021 4:41 am
thealanberman
(@thealanberman)
Nothing I've tried has completely fixed it. I disassembled the extruder, made sure all the parts were clear of debris, made sure all the gears could spin properly/interlocked properly, and put it back together... that helped some, but it still gets caught and makes noise when unloading filament.
It seems to stick on the very end of the filament when unloading. I generally just pull hard to get the final few inches of filament out. I hope I'm not damaging anything?
I may look into a different extruder at some point, if no better solution comes up. (I hear good things about the Bondtech ones?)
This post was modified před 4 years by thealanberman
Napsal : 13/12/2021 5:49 pm
MicDG
(@micdg)
So, I contacted support and I've been sent the following parts:
  • MINI-Extruder-front
  • MINI-Extruder-rear
  • Extruder motor pinion
Swapping these parts and playing a bit with the positioning when tightening the screws fixed the problem for me. I hope this can help you too.
Napsal : 20/12/2021 3:43 pm
1 lidem se líbí
Chris Barnes
(@chris-barnes)
Was there any more progress made to this problem?  It seems that I now too have this issue while loading and unloading.
Support sent me a new motor, a new Buddy board, new gears and pinion.
Napsal : 04/12/2022 4:43 pm
thealanberman
(@thealanberman)
It's been a while, but if I recall, the trick ended up being to just disassemble the extruder, give it a thorough cleaning to ensure there's no issues with the feeder-gear, and then putting it back together.
Napsal : 04/12/2022 10:07 pm
Prusb
(@prusb)
For anyone ending here like I did and not knowing what to do. I disassembled the extruder fully until the stepper motor was free. There was some dirt on the gears of the motor that I cleaned of(I think this was the issue). Then I turned the printer on and kept trying unload while assembling. first make sure the axis is spinning together with the gear by marking with a marker.
As soon as the other gear was in place I tried out unloading carefully because everything is disassembled. And this time it worked! No more sound! then I closed everything and tried one more time and it still worked 🙂
Napsal : 05/04/2024 7:08 pm
RD
 RD
(@rd-4)
this is the solution
Napsal : 16/04/2024 5:36 pm
