Loud fan noise when starting up and printing!
Fakejordan
(@fakejordan)
I clean the fan but not sure how to fix this. Is loud but only at start up and during prints. Any advices?
Much appreciated.
Fakejordan
Opublikowany : 28/10/2025 11:57 am
Fakejordan
(@fakejordan)
RE: Loud fan noise when starting up and printing!
https://youtube.com/shorts/UurY8jSDJrY?feature=share
Opublikowany : 28/10/2025 12:01 pm
_KaszpiR_
(@_kaszpir_)
Fan speed is to the max on printer start or (usually) first few layers in the print.
You can disassemble the fan, use a hot air to remove the sticker on the back of the fan and put in a one drop of machine oil (WD40 is not for that).
Leave it upside down for a 5 minutes, spin manually the fan few times so that the oil will go down through, then put the sticker back and assemble back the fan.
(Mine was rattling like a snake 😉 )
Opublikowany : 28/10/2025 10:31 pm
Fakejordan
(@fakejordan)
Posted by: @_kaszpir_
Thank you. I will try that.
Opublikowany : 29/10/2025 12:07 am
