        Loading Filament and Firmware 4.4.1 (Jan 2023) Original Mini
On my load filament menu which entry should I use for T-Glase? I want the filament to load and I want to be able to use print first layer calibration option.
I only recently upgraded firmware. Weren't there more menu choices before on the load filament menu?
Best Answer by carlmmii:
Just use the PETG setting, temps are close enough to rated range.
                            Opublikowany : 03/09/2023 8:17 am
                    RE: Loading Filament and Firmware 4.4.1 (Jan 2023) Original Mini
                            Opublikowany : 07/09/2023 5:48 am
                    Topic starter
 answered:
The PETG setting is 230/85. It could be closer. Thank you for responding. This looks like my best choice.
                            Opublikowany : 07/09/2023 6:31 pm
