Lasted 18 hours
Strona 2 / 2
Zoltan
(@zoltan)
Member Moderator
RE: Lasted 18 hours
Ah so, no problem, just the textile cover protects a bit the cables especially against the sharp edges of the box entrance cover . But never mind. Functionality first 😉
Opublikowany : 29/07/2020 9:53 am
towlerg
(@towlerg)
RE: Lasted 18 hours
@zoltan
"...after I have got my MINI, the not very old MK3S is saddly looking to me from a corner to be used. " Really? Dosen't say very much for the MK3s!
Opublikowany : 29/07/2020 10:02 am
Zoltan
(@zoltan)
Member Moderator
RE: Lasted 18 hours
@towlerg
do not misunderstand me 😉 , I like both of them. Sometimes they print in parallel - mk3 doing the large and Mini the small parts. They are complementary.
Opublikowany : 29/07/2020 1:38 pm
RE: Lasted 18 hours
@towlerg
sometimes the big ones look enviously at the little ones, but they would never admit that they are envious of whatever 😉 .
Opublikowany : 29/07/2020 1:43 pm
SteveB
(@steveb)
RE: Lasted 18 hours
Karl-Herbert: I have sent you a private message with contact details.
Opublikowany : 31/07/2020 11:31 am
towlerg
(@towlerg)
RE: Lasted 18 hours
@zoltan
"They are complementary." and "the not very old MK3S is saddly looking to me from a corner to be used." seem not to match but what the heek....
Opublikowany : 31/07/2020 2:10 pm
Zoltan
(@zoltan)
Member Moderator
RE: Lasted 18 hours
(@towlerg)
 Yesterday the mk3 was rather busy 😉  I needed to do larger (in size) job. It is normal, parents also care more about newborn baby until it grows a bit.
Do not tell me , when you got home a new toy, you did not put more attention to it than to the others. Now I have ordered a new oscilloscope, so for a while all other toys will get less care. 😀
Opublikowany : 31/07/2020 3:34 pm
towlerg
(@towlerg)
RE: Lasted 18 hours
@zoltan
"Now I have ordered a new oscilloscope" Oooh, what you getting?
Opublikowany : 01/08/2020 1:44 pm
RE: Lasted 18 hours
Posted by: @zoltan
(@towlerg)
What kind of oscilloscope did you buy? I would also like to get something suitable for private use. What would you recommend?
Opublikowany : 01/08/2020 5:10 pm
Zoltan
(@zoltan)
Member Moderator
RE: Lasted 18 hours
I got a recommendation from my good colleague for dso ds213 ordered it from aliexpress from germany stock ,considered to be received next week.
For measuring along MINI like fan tacho signals etc. should be fine and is handy - pocket size. After I receive I will let you know how it works.
Opublikowany : 01/08/2020 6:57 pm
SteveB
(@steveb)
RE: Lasted 18 hours
Thanks but I am not going to start learning electronics in order to use a 3D printer. I can probably change a nozzle. My Mini has a buyer so it will disappear from my household very soon.
Opublikowany : 01/08/2020 8:45 pm
RE: Lasted 18 hours
@zoltan
Thanks for the info! I think you mean this one: New Handheld Digital Oscilloscope DSO DS213 2CH 15MHz 100MSa/s Signal Generator DSO212 2CH 1MHz 10MSa/s . I look forward to your feedback.
Opublikowany : 01/08/2020 11:21 pm
Zoltan
(@zoltan)
Member Moderator
RE: Lasted 18 hours
@53stephen
this was not my intention at all, I am sorry you are going to give up. However recently the level of 3d printers intelligence is not that high, that you only give it the idea and everything will be done by them.
Or probably there are some of them, but than the price will look at least adding two zeros on the right side, before the comma.  😉
Opublikowany : 02/08/2020 4:11 pm
RE: Lasted 18 hours
@zoltan
agree 👍  - but human intervention will always be necessary, even with a 1 million dollar printer.
Opublikowany : 02/08/2020 4:25 pm
Strona 2 / 2
