LAN settings cleared every power off
chipmen
(@chipmen)
Membre
Hi i testing FW 4.3.2, now 4.3.3, when i set static ip adress is web functional. But after next power on, ip adress is missing. I have connection, remember static, but ip/mask/gw is set to 0.0.0.0.  I dont want every printer start loading ip configuration, how to set it to forever?
Publié : 17/10/2021 7:44 pm
Membre
Clone?
Is this a clone?
Publié : 27/10/2021 6:54 pm
chipmen
(@chipmen)
Membre
Not Clone, its original
No, its a original printer from Prusa, one year old.
Publié : 27/10/2021 7:49 pm
Membre
Appendix
Did you remove the appendix?
I will test it tonight.  I am trying to see if I have the same setup on one of mine.
Publié : 27/10/2021 8:17 pm
chipmen
(@chipmen)
Membre
Configuration
So here is my configuration(lan_settings.ini):
[lan_ip4]
type=STATIC
hostname=PrusaMINI
address=10.10.10.10
mask=255.255.255.0
gateway=10.10.10.1
Publié : 27/10/2021 8:27 pm
K7ZPJ
(@k7zpj)
Lan Settings are stored on the USB drive
The lan settings are stored on the USB drive in the file lan_settings.ini.   When you select save settings the updates are written to the USB drive not to the printers memory.
The printer reads the lan_settings.ini file from the USB drive when the printer powers up or when you select load settings
To see how it works, power up the printer with USB inserted with lan_settings.ini on it and then try powering it up with out the USB.
Publié : 27/10/2021 9:18 pm
chipmen
(@chipmen)
Membre
Where stored LAN setting in Prusa Mini
Sorry i use this manual https://help.prusa3d.com/en/article/prusa-connect-local-mini_133279 for my LAN settings. In this manual nowhere any information about necessary configuration lan settings every starting. Its like a joke, after over 20years in IT, this is first lan device which dont remember LAN setting in its motheboard eeprom/flash??? Do you really mean, I must every start have this one flash with lan configuration, in USB port to lan is set? This must be a joke a dont believe that.
Publié : 28/10/2021 7:05 am
