Ironing doesn't look good
In the picture below I have marked places where the ironing has not worked. There are very visible bumps and marks in the upper surface.
Also notice that the two lower items are almost ok, but the upper two are definitely not good.
Any Idea wky?
I use prusa slicer, the settings used are normal prusament PLA with 0.2 mm layer height, plus: 1 mm upper layer and ironing enabled at 15% speed.
Respondido : 10/04/2024 7:58 am
