intermittent layer Shift in X-Direction
On at least two prints, 8 and 16 hours, I seem to get these layer shift/ jumps. almost as if there is a spike in error, it drifts back to the correct alignment, and another error spike. Any ideas? I've seen about loose grub screws on drive pulleys, causing X-direction shifting, but the images don't seem to align with the same error I am seeing.
Publié : 23/03/2021 9:19 am
RE: intermittent layer Shift in X-Direction
I'm not an expert but I think this looks like a belt tension issue. You can use this to set it up perfectly or you can do it by ear.
https://help.prusa3d.com/en/article/adjusting-belt-tension-mini_157324
Publié : 29/03/2021 7:08 pm
