How edit and compile firmware to MINI+
Strona 2 / 2
BogdanH
(@bogdanh)
Changing only bed (Y) size is not a problem.. but how about auto-bed-leveling positions and homing?
You have quite special hardware change and so I recommend that you compile firmware yourself. Because of two reasons: New firmware versions will be released in future and you would sure wish to have it. And second, if something goes wrong with firmware (compiled by someone else), nobody wish to take blame for that -I'm sure you understand what I mean.
Btw. what does "i have change the size in visual coded.." mean? You should use Notepad (or similar "plain" text editor) to change firmware parameters.
[Mini+] [MK3S+BEAR]
Opublikowany : 13/10/2021 7:28 am
buggyfreak
(@buggyfreak)
compile
i have change the following code ( https://github.com/FYSETC/FYSETC-Prusa-mini-clone-plus/tree/main/firmware) using visual code:
In file src/gui/gui_config_mini.h following define is changed.
#define Y_LEN 253
In file include/marlin/Configuration_A3ides_2209_MINI.h following defines are changed.
#define Y_BED_SIZE 250 #define Y_MIN_POS -6
now is to compile. which i dono how to use python.
please advice on how to use the python. i have install. when i open it show ">>" i try to type in and enter, it shows syntax error.
i try to use command prompt. it shows python was not found.
Opublikowany : 13/10/2021 9:49 pm
3Delight
(@3delight)
Moderator Moderator
Find them here...
Check out the instructions on the Prusa GitHub page here: https://github.com/prusa3d/Prusa-Firmware-Buddy#readme
Opublikowany : 13/10/2021 10:14 pm
ryan thorp
(@ryan-thorp)
RE: How edit and compile firmware to MINI+
i get this error is there some way i can fix it ModuleNotFoundError: No module named 'polib'
Opublikowany : 22/11/2021 4:39 pm
EpicMount
(@epicmount)
I was unable to build the *.BBF files with the flag --generate-bbf. However running the flag "--generate-dfu" created the BFF files in the \build\products folder.
This was in Windows 10
Opublikowany : 25/11/2021 3:53 am
Anxodia
(@anxodia)
Hello. Can anyone tell me what I did do wrong? I have no clue what Im doing I just want to change few parameters. But I tried to compile with unchanged firmware.
Help would be greatly appreciated, Thanks in advance!
Best, Anxodia
Opublikowany : 27/05/2022 1:42 am
towlerg
(@towlerg)
Are you sure you should continue. What are you trying to change?
Opublikowany : 28/05/2022 2:35 pm
Guru von Pospi LEE
(@guru-von-pospi-lee)
Hi all once again. I was a time and I was prepared a next printer upgrade Axis Z. I need help with configuration Axis Z. On the original is a Axis Z 180mm and changing to new parameter 230mm. I look on the Configuration_A3ides_2209_MINI.h, but I do not find where I must changing the Axis Z. Please it is here anybody who will help with this?
On the file I was find only the configuration and changing, but changing not funktion and the AXIS Z is 180mm.
// Travel limits (mm) after homing, corresponding to endstop positions.
#define X_MIN_POS -2#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define X_MAX_POS X_BED_SIZE
#define Y_MAX_POS Y_BED_SIZE
#define Z_MAX_POS 230
#ifdef USE_PRUSA_EEPROM_AS_SOURCE_OF_DEFAULT_VALUES
#define DEFAULT_Z_MAX_POS 230
#define Z_MIN_LEN_LIMIT 1
#define Z_MAX_LEN_LIMIT 10000
#else
#endif
Opublikowany : 31/08/2022 10:03 pm
Curtis
(@curtis-2)
Hi all, I have a similar upgrade to my MINI, except I'm making it 5 times longer. All the physical hardware has been modified, but now for some reason my screen won't turn on and the buttons don't do anything. The printer is acting very strange. I was hoping to flash the firmware but I can't figure out how to do so without the screen. Fuses are all good, hardware is all in order. Pronterface can control the printer but not consistently and sometimes the controls do things they shouldn't. Like When I try to move on the X axis, it'll move on the Y axis instead. I have no clue...
Any ideas would be greatly appreciated!
Opublikowany : 12/02/2023 9:38 pm
princeba
(@princeba)
Hi There, thanks for this thread I have been searching for something like this for long. But now that I have it, I think there might be some changes in the code that I can located or know exactly which file configuration.h file I can make the changes to. Anyone with any idea can help me out. thank you
Opublikowany : 03/04/2023 2:10 am
tjmitchem
(@tjmitchem)
I hit an interesting error compiling the firmware on OpenSuSE.
firmware section `.data' will not fit in region `FLASH'
region `FLASH' overflowed by 3692 bytes
ninja: build stopped: subcommand failed.
Has anyone else seen something like this?
Opublikowany : 08/07/2023 8:33 pm
Ma
 Ma
(@ma)
hello after numerous problems i have installed the custom firmware
1) do not download pithon 3.12 something is missing i have pithon 3.11.7 "include PATH"
2) check that pithon has all the packages
https://packaging.python.org/en/latest/tutorials/installing-packages/
restart the computer after installing Pithon. open cmd as administrator and enter the following commands for Windows
py --versionpy -m
pip --versionpy -m Guaranteepip --default-pippy -m
pip --versionpy -m
pip install --upgrade
pip setuptools wheelpy -m venv
tutorial_envtutorial_env\Scripts\activate
3) install virtualenv
https://virtualenv.pypa.io/en/latest/installation.html
restart your computer, open cmd as administrator and enter the following commands for Windows
python -m pip install --user virtualenv
python -m virtualenv --help
4) install the Microsoft Visual C++ compilation tool to eliminate errors Microsoft Visual C++ 14.0
https://learn.microsoft.com/en-us/answers/questions/136595/error-microsoft-visual-c-14-0-or-greater-is-requir
restarts the computer
download link: https://visualstudio.microsoft.com/it/visual-cpp-build-tools/
5) run "python -m venv .venv" which bypasses an error via previously installed virtualenv
https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/3579
cd x:\Prusa-Firmware-Buddy-5.1.2
python -m venv
cd x:\Prusa-Firmware-Buddy-5.1.2 is the directory of the file instead of "x" is the path to the file (note: deleting the double subdirectory is equivalent to e.g. g:\Prusa-Firmware-Buddy- 5.1.2\Prusa-Firmware-Buddy-5.1.2)
6) if you don't find the firmware file to be modified are x:\Prusa-Firmware-Buddy-5.1.2\includingemarlin\Configuration_MINI.h
and change e.g. max. nozzle temperature to 300:
#define HEATER_0_MAXTEMP 290 --> 315
or max. bed temperature to 110:#define BED_MAXTEMP 110 --> 120
7) Start the firmware compilation with 'python utils/build.py --preset mini --generate-bbf' in this order
python utils/build.py --preset mini,xl --generate-bbf
if there are any errors, I recommend restarting the computer and repeating step 7 (this one)
This post was modified 2 years temu 2 times by Ma
Opublikowany : 02/01/2024 10:30 pm
Ma
 Ma
(@ma)
p.s.
disable firewall and real-time protection to eliminate other errors and the link to download 5.1.2 Firmware for Original Prusa MINI, MK4, MK3.9 & XL, the file is "Source code (zip)".
download link: https://github.com/prusa3d/Prusa-Firmware-Buddy/releases
Opublikowany : 02/01/2024 10:59 pm
singlefin
(@singlefin)
Guys, I need help to compile a custom firmware for my Mini Bear but I am having trouble compiling it on my Mac OS 15.2 Airbook.  I successfully compiled a firmware a couple years back but somehow I'm running into the following error messages.  Any help would be greatly appreciated!  Thank you and happy holidays!
peter@MacBookAir Prusa-Firmware-Buddy-5.1.0 % python3 utils/build.py
Switching to Buddy's virtual environment.
You can disable this by setting the BUDDY_NO_VIRTUALENV=1 env. variable.
Traceback (most recent call last):
  File "/Users/peter/Prusa-Firmware-Buddy-5.1.0/utils/build.py", line 832, in
    main()
  File "/Users/peter/Prusa-Firmware-Buddy-5.1.0/utils/build.py", line 623, in main
    bootstrap.switch_to_venv_if_nedded()
  File "/Users/peter/Prusa-Firmware-Buddy-5.1.0/utils/bootstrap.py", line 211, in switch_to_venv_if_nedded
    os.execv(str(venv_bin_dir / 'python'),
FileNotFoundError: [Errno 2] No such file or directory
This post was modified 12 months temu by singlefin
Opublikowany : 20/12/2024 10:01 am
singlefin
(@singlefin)
Problem solved, used ChatGPT and it created a list of work arounds.
Opublikowany : 23/12/2024 8:18 am
Good luck, I still remember the ChatGPT gingerbread recipie that included a cupful of spoons.
Opublikowany : 23/12/2024 1:53 pm
1 ludzie polubili
pilotedge
(@pilotedge)
Hi all,
I'm having loads of issues with the simpliest of things. I'm getting a module not found error after cloning the git and then running the build script. I assumed it was because I just didn't have the module (requests) but I do, it is showing as installed, and weirdly I am having the same issue on my WSL instances as well as on Visual Code Studio. Has anyone else had this issue?! Is it me being a Python noob or is it something else!
Opublikowany : 01/02/2025 9:17 am
Strona 2 / 2
