Hot End Leaking-Help
miles-h2
(@miles-h2)
The leak can be seen by the yellow arrow. Do I need new parts or is it a maintenance problem? Any help appreciated, Thanks, Miles
Postato : 20/12/2021 9:23 pm
RE: Hot End Leaking-Help
Easy problem. Incorrectly assembled hotend - nozzle tightened against the heat block not the heat break.
If correctly assembled there's a gap between the nozzle and the bottom of the heater block
Carefully follow the instructions in Prusa's Knowledgebase:
Mk3S https://help.prusa3d.com/en/article/changing-or-replacing-the-nozzle_2069
Mini https://help.prusa3d.com/en/article/changing-replacing-the-nozzle-mini_134235
Postato : 21/12/2021 12:35 am
