RE: Hot End Leaking-Help
Easy problem. Incorrectly assembled hotend - nozzle tightened against the heat block not the heat break.
If correctly assembled there's a gap between the nozzle and the bottom of the heater block
Carefully follow the instructions in Prusa's Knowledgebase:
Mk3S https://help.prusa3d.com/en/article/changing-or-replacing-the-nozzle_2069
Mini https://help.prusa3d.com/en/article/changing-replacing-the-nozzle-mini_134235
Publié : 21/12/2021 12:35 am
