Help tighten or replace the Y axis belt …
Mtnplaya
(@mtnplaya)
I need to tighten the Y axis belt and using the screws on the ends is not doing it. How do I make them tighter? I don’t understand how to reduce the lag in the Y axis belt
Opublikowany : 12/01/2025 7:34 pm
RE: Help tighten or replace the Y axis belt …
See https://help.prusa3d.com/article/adjusting-belt-tension-mini-mini_157324
From the second photo you seem to have quite a bit of space left for the lower end of the belt to be moved in further.
Opublikowany : 13/01/2025 2:00 pm
