Having trouble with print quality (under-extrusion) after printing with relatively no problem for a year or so.
[Risolto] Having trouble with print quality (under-extrusion) after printing with relatively no problem for a year or so.
Pagina 3 / 9
Hello
(@hello)
RE: Having trouble with print quality (under-extrusion) after printing with relatively no problem for a year or so.
then do a cold pull https://help.prusa3d.com/article/cold-pull-mini_126399
Postato : 02/01/2023 10:43 pm
Hello
(@hello)
and print this please print with skirt and dont stop it unless it slips off bed thanks
Postato : 02/01/2023 10:50 pm
harmlessVI
(@harmlessvi)
Alright, I don't think there is but I will keep an eye on it while it does the calibration.
Postato : 02/01/2023 10:51 pm
Hello
(@hello)
print please
Postato : 02/01/2023 10:52 pm
harmlessVI
(@harmlessvi)
Here is a first layer calibration, will try other stuff here in a second.
Postato : 02/01/2023 11:01 pm
Hello
(@hello)
now ive got picture thanks
Postato : 02/01/2023 11:02 pm
1 persone hanno apprezzato
Hello
(@hello)
soryy image is a bit fuzzy if you still have it can you zoom in on the square please
Postato : 02/01/2023 11:05 pm
Hello
(@hello)
and if no of that works try tighten the extruder gear screw a little bit not as much as you originally had it but a bit tighter then what it is now
Postato : 02/01/2023 11:14 pm
Hello
(@hello)
hows it going
Postato : 02/01/2023 11:19 pm
harmlessVI
(@harmlessvi)
About to work on it
Postato : 02/01/2023 11:52 pm
Hello
(@hello)
ok
Postato : 02/01/2023 11:57 pm
Hello
(@hello)
hows it going
Postato : 03/01/2023 12:19 am
harmlessVI
(@harmlessvi)
Did a few cold pulls, about to print test. I also tightened the extruder bolt a smidge.
Postato : 03/01/2023 12:23 am
Hello
(@hello)
ok fingers crossed for this print
Postato : 03/01/2023 12:27 am
harmlessVI
(@harmlessvi)
Worked pretty good until the last couple layers, not quite sure what the deal was with the brim.
Postato : 03/01/2023 12:35 am
harmlessVI
(@harmlessvi)
Print settings for that.
Postato : 03/01/2023 12:36 am
Hello
(@hello)
ok so quite a bit of stringeness
Postato : 03/01/2023 12:39 am
harmlessVI
(@harmlessvi)
yes indeed
Postato : 03/01/2023 12:40 am
Hello
(@hello)
you can see the lines how old is the fillament
Hello
(@hello)
try do a first layer cal again and take close up photo of the square
Pagina 3 / 9
