Having trouble with print quality (under-extrusion) after printing with relatively no problem for a year or so.
[Gelöst] Having trouble with print quality (under-extrusion) after printing with relatively no problem for a year or so.
Seite 2 / 9
Hello
(@hello)
RE: Having trouble with print quality (under-extrusion) after printing with relatively no problem for a year or so.
If yo caRnt get one don't worry have you try lowering the print speed as the first layer does it a lot slower so try lower print speed and see if it works
Thanks
Veröffentlicht : 02/01/2023 8:02 pm
harmlessVI
(@harmlessvi)
Here is a video of the filament being loaded:
https://drive.google.com/file/d/109DtPCCSl2meDl3M70PK4pP4XYyQCxWa/view?usp=share_link
Veröffentlicht : 02/01/2023 9:28 pm
Hello
(@hello)
Yes that's good so it loads fine try lower print speed just to see
Veröffentlicht : 02/01/2023 9:39 pm
harmlessVI
(@harmlessvi)
Alright I will give that a shot, in the mean time, here is a video after that loading of a benchy attempt.
https://drive.google.com/file/d/17dRxQ5W0qalei123X_1RnG__vbnd941p/view?usp=share_link
Veröffentlicht : 02/01/2023 9:41 pm
Hello
(@hello)
caRnt play video coming up with error
Veröffentlicht : 02/01/2023 9:43 pm
harmlessVI
(@harmlessvi)
It may take a few minutes to process, I just uploaded to drive
Veröffentlicht : 02/01/2023 9:44 pm
Hello
(@hello)
Oh ok It saying yes I'm just downloading now
Veröffentlicht : 02/01/2023 9:45 pm
Hello
(@hello)
It's working now
Veröffentlicht : 02/01/2023 9:46 pm
Hello
(@hello)
Yes as I thought your printing speed is quite fast
Veröffentlicht : 02/01/2023 9:48 pm
harmlessVI
(@harmlessvi)
This is at 80 speed instead of 100, also at 215c the whole time.
Veröffentlicht : 02/01/2023 10:00 pm
Hello
(@hello)
wow that is complete disastr just to see can you print at 200 degress please
Veröffentlicht : 02/01/2023 10:08 pm
harmlessVI
(@harmlessvi)
Yep I will give that a shot
lol it really  is a disaster
Veröffentlicht : 02/01/2023 10:17 pm
Hello
(@hello)
and see if it can print this its just a 20 mm  by 20mm box this may be able to tell us where its going wrong print 215 degress and normal speed thanks
New Compressed (zipped) Folder
Hello
(@hello)
Hows it going
Veröffentlicht : 02/01/2023 10:31 pm
harmlessVI
(@harmlessvi)
Here is what happened, ran it at 215c and 100 (default) speed using the 0.15mm present and hatchbox filament in prusaslicer.
Failed on the second layer and had a few rough bits on the first.
Veröffentlicht : 02/01/2023 10:34 pm
Hello
(@hello)
ok can you redo the first layer cal again
Veröffentlicht : 02/01/2023 10:37 pm
harmlessVI
(@harmlessvi)
Yep
Veröffentlicht : 02/01/2023 10:38 pm
Hello
(@hello)
have you removed nozzle recently
Veröffentlicht : 02/01/2023 10:39 pm
harmlessVI
(@harmlessvi)
I did yesterday to see if anything was wrong with it along with the ptfe tube, seemed fine. I put it back on per the assembly instructions that I found online.
Veröffentlicht : 02/01/2023 10:41 pm
Hello
(@hello)
just make sure its tight and nothing is leaking from around the heat block
Veröffentlicht : 02/01/2023 10:43 pm
Seite 2 / 9
