G Code question - Modify wipe?
lurc
 lurc
(@lurc)
Is it possible to modify the wipe that the printer does immediately before printing?
As my printer comes to temperature it tends to produce a blob of filament. As it moves straight down right before the wipe, that blob gets pushed up into the nozzle. Often that blob ends up hanging on long enough to make it to the print. I'd like to change the wipe so that as the head is moving down it has already started to move sideways. This way the blob might begin to grab the sheet and get spread out into that wipe, instead of hanging onto my nozzle.
I see this in the start G code but honestly not sure where to start as I don't speak g code:
; intro line
G1 X170 F1000G1
Z0.2 F720
G1 X110.0 E8.0 F900
G1 X40.0 E10.0 F700
G92 E0.0
Any help is most appreciated!
Veröffentlicht : 02/02/2022 2:43 am
Bob
 Bob
(@bob-2)
RE: G Code question - Modify wipe?
I keep a pair of tweezers next to my printer.  As it approaches temperature I pluck off the strand.  Since it's a wise idea to watch your first layer or two this suits me.
Cheers
-Bob
Veröffentlicht : 02/02/2022 2:57 am
lurc
 lurc
(@lurc)
I do cut off any remaining bits from the prior print.
I'm not fast enough to reach in with a pair of tweezers and cleanly grab a blob of filament in the couple of seconds that the temp causes the blob. It's also too low for me to see the back side.
Maybe if it were a little higher I could?
Is it possible to tweak to code to have it start off higher?
Diese r Beitrag wurde geändert Vor 4 years von lurc
Veröffentlicht : 02/02/2022 3:18 am
For anything that is going to matter I wipe the nozzle with a fragment of filament as the extruder starts moving.  Just use a scrap from a previous unload, it sticks to the dangle, if present, really well.
Veröffentlicht : 02/02/2022 9:51 am
lurc
 lurc
(@lurc)
Posted by: @diem
I tried that using a previous wipe line and it's difficult, but yes, it does work a little better (for me) than trying to grab with tweezers.
It would be "really easy" if I could have it do the warmup from a higher position. So I'd still like to know how to get it to come up to temp for the wipe line from say 10mm higher.
So if anyone can help me with that, I would appreciate it.
Veröffentlicht : 02/02/2022 2:58 pm
lurc
 lurc
(@lurc)
I think I have answered my own question by learning a bit of G-code. But the movement is boxy and I would prefer for it to be a smooth arc of some sort. I will keep refining it until I have a solution, but for now, I modified the original G Code from this:
M83 ; extruder relative mode
M104 S170 ; set extruder temp for bed leveling
M140 S[first_layer_bed_temperature] ; set bed temp
M109 R170 ; wait for bed leveling temp
M190 S[first_layer_bed_temperature] ; wait for bed temp
G28 ; home all without mesh bed level
G29 ; mesh bed leveling
M104 S[first_layer_temperature] ; set extruder temp
G92 E0.0
G1 Y-2.0 X179 F2400
G1 Z3 F720
M109 S[first_layer_temperature] ; wait for extruder temp
; intro line
G1 X170 F1000
G1 Z0.2 F720
G1 X110.0 E8.0 F900
G1 X40.0 E10.0 F700
G92 E0.0
M221 S95 ; set flow
To this:
G92 E0.0
G1 Y-2.0 X179 F2400
G1 Z15 F720
; intro line
G1 X170 F1000
G1 Z8 F720
G1 X165.0 E8.0 F900
G1 Z8 F720
G1 X160.0 E8.0 F900
G1 Z4 F720
G1 X155.0 E8.0 F900
G1 Z2 F720
G1 X150.0 E8.0 F900
G1 Z0.2 F720
G1 X110.0 E8.0 F900
G1 X40.0 E10.0 F700
G92 E0.0
M221 S95 ; set flow
Veröffentlicht : 02/02/2022 3:49 pm
lurc
 lurc
(@lurc)
oops. Slight change to the steps will make it a hair smoother:
G92 E0.0
G1 Y-2.0 X179 F2400
G1 Z15 F720
; intro line
G1 X170 F1000
G1 Z8 F720
G1 X165.0 E8.0 F900
G1 Z6 F720
G1 X160.0 E8.0 F900
G1 Z4 F720
G1 X155.0 E8.0 F900
G1 Z2 F720
G1 X150.0 E8.0 F900
G1 Z0.2 F720
G1 X110.0 E8.0 F900
G1 X40.0 E10.0 F700
G92 E0.0
M221 S95 ; set flow
Veröffentlicht : 02/02/2022 3:58 pm
OR:  Press and hold the button until it switches to the Z height display then dial it up as far as you need.
Veröffentlicht : 02/02/2022 4:40 pm
lurc
 lurc
(@lurc)
OK. Success!
I'd love for it to be an exponential decaying arc but that is more math than I want to get into.
Here is the code. I ended up lowering the z before the intro line to 6. The 15 I had it set to was unnecessary but I had to start someplace.
G92 E0.0
G1 Y-2.0 X179 F2400
G1 Z6 F720
; intro line
G1 X170 Z5 F1000
G1 X135.0 Z2.5 E8.0 F720
G1 X115.0 Z0.2 E8.0 F720
G1 X110.0 E8.0 F720
G1 X40.0 E10.0 F700
G92 E0.0
M221 S95 ; set flow
I will upload a video of how this works shortly.
Veröffentlicht : 02/02/2022 4:51 pm
lurc
 lurc
(@lurc)
Video is uploading now:
Veröffentlicht : 02/02/2022 5:17 pm
Chris Laudermilk
(@chris-laudermilk)
Nice. Learning is part of the fun of this hobby.
Mini+ (kit) - Revo Micro | Antler Cooling | WiFi (4.4.0RC1)
Veröffentlicht : 03/02/2022 3:59 pm
KineMechanic
(@kinemechanic)
Really cool solution!
This has annoyed me too and I always wait and grab the blob with pliers (or my fingers).
I might give this a try.
It would save me this minor nuisance.
Thanks for sharing!
Veröffentlicht : 10/02/2022 10:22 pm
Ichschonwieder
(@ichschonwieder)
Thanks for sharing!
Added the configuration and it seems to work well.
Veröffentlicht : 14/02/2022 9:58 am
