Extruder Re-Assembly
I disassembled my Mini extruder to clean the filament contact grooves with a sewing needle (tedious...) The extruder assembly has 5 nuts - one of them has a nylon insert. I lost track of where it goes. Looking at my two pictures, can you tell me where it goes (1 through 5)?
Opublikowany : 15/03/2020 2:32 pm
RE: Extruder Re-Assembly
Pretty sure it's hole #2, flat part of the nut inward. The nylon part will stick out a bit, which goes into a recess in the part that remains attached to the Z axis.
Hear ye, Hear ye! Step right up folks and get your Government salvation here! Less than $.002 per word! Amazon.com/dp/B0B8XMMFP4
Opublikowany : 15/03/2020 3:23 pm
