Extruder on reverse
mariostevaux
(@mariostevaux)
Extruder on reverse
I reset my Prusa Mini to Factory Settings. Since then when I set the command on the screen to load the filament the extruder runs on reverse trying to unload. If I select Unload, the extruder tries to load the filament. Any idea on how to fix it?
Ce sujet a été modifié il y a 3 years par mariostevaux
Publié : 22/02/2022 11:05 pm
RE: Extruder on reverse
Do you have the Bondtech extruder? There's an option to set the direction of the extruder, which is necessary for the Bondtech. If you don't have the Bondtech, maybe it somehow reversed otherwise. The setting is in the LCD Menu under Settings. Scroll to HW setup and then press the knob for 2 to 3 seconds to get to the "experimental menu". Look for Extruder dir. Also see https://help.prusa3d.com/en/article/experimental-menu-mini-mini_264396/ for more details.
Publié : 23/02/2022 12:35 pm
2 personnes ont aimé
mariostevaux
(@mariostevaux)
Great it worked, thank you very much
Publié : 25/02/2022 10:27 pm
Lichtjaeger
(@lichtjaeger)
Also, if you have a Bondtech you should set the steps/mm to 415 in that menu.
Publié : 26/02/2022 7:13 am
Curtis Gregorash
(@curtis-gregorash)
Membre
You are a GOD, thank you! Experimental Menus WTF!!!???
Ce message a été modifié il y a 11 months par Curtis Gregorash
Publié : 29/07/2024 11:38 pm
