Error 28? PrusaSlicer seeing an old IP address
Tom Husband
(@tom-husband)
Today, after not printing for a few weeks, I get:
Error uploading to print host:
Timeout was reached:
Connection timed out after 10005 milliseconds
[Error 28]
I'm using OctoPrint on an Ethernet connected Raspberry Pi and PrusaSlicer on a Win 10 laptop (also Ethernet connected).
OctoPrint connects to my Mini+ and I can see it on my laptop.
What's error 28? I can't seem to find the error code anywhere.
When PrusaSlicer tries to upload the gcode it's referencing an old IP address for Octoprint (I recently changed routers).How do I updated that IP address? I've already uninstalled and re-installed PrusaSlicer but it didn't help. I've looked all over in Preferences but can't see where to update that. I'm pretty sure that's the problem.
Probably something simple that I'm missing.
Thanks for any help.
Napsal : 12/02/2023 10:40 am
Tom Husband
(@tom-husband)
RE: Error 28? PrusaSlicer seeing an old IP address
Never mind I got it. I finally found where to change the IP address. All is well.
Napsal : 12/02/2023 10:51 am
TeachThePrints
(@teachtheprints)
In case anyone else is searching for this:
In PrusaSlicer go to the printer drop-down menu and select "edit physical printer". This will open a popup where the IP can be set.
Prusa Mini FW6.2.4
Napsal : 13/02/2023 11:58 am
1 lidem se líbí
Tom Husband
(@tom-husband)
Thanks, I should have done that.
Napsal : 13/02/2023 4:11 pm
