End of print - Sound - Prusa Mini
Ted
 Ted
(@ted)
When will the Prusa Mini learn to play a sound at the end of the print, i.e.: accept an M300 command?
I read about the great new board and the new software, but why can't it work out such a simple command?
Thanks for a (technical) explantion!
Napsal : 14/09/2021 1:18 pm
Zoltan
(@zoltan)
Member Moderator
Re
You can check the prusa git site, there is probably a feature request there.
Napsal : 20/09/2021 6:42 pm
Ted
 Ted
(@ted)
RE: Re Re
Thanks Zoltan,
I  am aware of the Feature request on Github, it dates from the 21st of November 2020.... how many new firmware versions were there since then? I think the number is double figures!
So I think that the engineers at Prusa are not willing to do something about it... - that it can be done is proven by > https://github.com/matthewlloyd/Llama-Mini-Firmware#readme < but I am still undecided if I should go for an irreversible and warranty voiding procedure?!
What puzzles me is, why the firmware guys at Prusa can't do it and this was the reason for asking for a 'more technical explanation'!
Anyone of Prusa is reading this?
This post was modified před 5 years 2 times by Ted
Napsal : 20/09/2021 7:35 pm
