Difference between GTK2 and GTK3 files?
I recently moved from Windows to Linux Mint and want to update to PrusaSlicer 2.6.0. When I download the appimages I a GTK2 and GTK3 version. Which should I be using? I'm currently using version 2.5.2 so I must have selected one of the versions but I don't remember. I'd assume it's GTK3 but just want to make sure.
Many thanks.
Best Answer by Diem:
We are starting to see gtk4 now...
You are almost certain to be using gtk3.nn - unless you are running a 32bit core on older equipment when gtk2 would be more efficient.
Download both appImages, the 'wrong' one will not cause damage, it will just fail to run.
RE: Difference between GTK2 and GTK3 files?
Thanks for confirming, I thought so.
