					                		Did my first maintenance, and ruined my printer... - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/did-my-first-maintenance-and-ruined-my-printer/</link>
                <lastBuildDate>Mon, 15 Jun 2026 23:32:08 +0000</lastBuildDate>
                        <title>RE: Did my first maintenance, and ruined my printer...</title>
                        <link>https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/did-my-first-maintenance-and-ruined-my-printer/#post-598165</link>
                        <pubDate>Fri, 25 Mar 2022 04:36:36 +0000</pubDate>
                        <description><![CDATA[In my case I was getting clicks due to the spring door being too tight. I loosened it more that being flush and it stopped having issues.]]></description>
                        <content:encoded><![CDATA[<p>In my case I was getting clicks due to the spring door being too tight. I loosened it more that being flush and it stopped having issues.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>LegoYoda</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/did-my-first-maintenance-and-ruined-my-printer/#post-598165</guid>
                        <link>https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/did-my-first-maintenance-and-ruined-my-printer/#post-592006</link>
                        <pubDate>Fri, 11 Mar 2022 17:00:54 +0000</pubDate>
                        <description><![CDATA[...or are just one or two teeth in the extruder clogged?Cheerio,]]></description>
                        <content:encoded><![CDATA[<p>...or are just one or two teeth in the extruder clogged?</p><p>Cheerio,</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Diem</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/did-my-first-maintenance-and-ruined-my-printer/#post-592006</guid>
                        <link>https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/did-my-first-maintenance-and-ruined-my-printer/#post-591856</link>
                        <pubDate>Fri, 11 Mar 2022 12:50:03 +0000</pubDate>
                        <description><![CDATA[I don&#039;t know... this pattern looks way too regular for me to believe it&#039;s caused by idler tension or a partial clog. It almost feels like there&#039;s an obstruction that blocks filament every fe...]]></description>
                        <content:encoded><![CDATA[<p>I don't know... this pattern looks way too regular for me to believe it's caused by idler tension or a partial clog. It almost feels like there's an obstruction that blocks filament every few centimeters. Maybe it's just a crazy idea but I'd check to make sure there's nothing blocking the filament either on the spool itself or at the spool holder. With the spool turning and hitting something once a turn that could explain the pattern you're seeing. Or maybe the set screw on the extruder axle slipping. But then I'd expect to see a lot more, less regular under extrusion than the regular pattern you're seeing. </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>FoxRun3D</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/did-my-first-maintenance-and-ruined-my-printer/#post-591856</guid>
                        <link>https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/did-my-first-maintenance-and-ruined-my-printer/#post-591835</link>
                        <pubDate>Fri, 11 Mar 2022 12:34:53 +0000</pubDate>
                        <description><![CDATA[I understand what you mean by &quot;circling in circles.&quot; Don&#039;t take these criteria too literally when it comes to establishing &quot;correct&quot; extrusion with idler... they&#039;re simply that. If flawless ...]]></description>
                        <content:encoded><![CDATA[<p>I understand what you mean by "circling in circles." Don't take these criteria too literally when it comes to establishing "correct" extrusion with idler... they're simply that. If flawless instructions exist, then that tension screw should have a gauge or scale on it. So, keep the following guidelines in mind and do it by "feeling": there should be enough grip for the extruder to push filament into the hotend, but not too much grip, since this would damage the filament within the extruder (which again, will cause under-extrusion).You should probably just conduct load/unload filament for experimentation (to avoid wasting time and filament on printing). Check the surface of the filament after it has been unloaded... there should only be minor evidence of gear teeth grasping.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>jerrybakermr</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/did-my-first-maintenance-and-ruined-my-printer/#post-591835</guid>
                        <link>https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/did-my-first-maintenance-and-ruined-my-printer/#post-468460</link>
                        <pubDate>Tue, 06 Jul 2021 18:58:46 +0000</pubDate>
                        <description><![CDATA[I know what you mean by &quot;going in circles&quot;. About setting &quot;right&quot; extrusion with idler.. don&#039;t take take these guidelines too literary.. they&#039;re just guides. If perfect instructions would ex...]]></description>
                        <content:encoded><![CDATA[<p>I know what you mean by "going in circles". About setting "right" extrusion with idler.. don't take take these guidelines too literary.. they're just guides. If perfect instructions would exist, then there should be some gauge or scale on that tension screw. So, keep guides in mind and do it by "feeling": there must be enough grip, so extruder is capable to push filament into hotend.. but at the same time, there shouldn't be too much grip, because that would damage filament inside extruder (which again, will cause under-extrusion).<br />For experimenting, you should maybe only do load/unload filament (so you don't waste time and filament on printing). And when filament is unloaded, check it's surface .. there should only be small traces of gear teeth gripping filament. Take your time and you'll succeed.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>BogdanH</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/did-my-first-maintenance-and-ruined-my-printer/#post-468460</guid>
                        <link>https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/did-my-first-maintenance-and-ruined-my-printer/#post-468427</link>
                        <pubDate>Tue, 06 Jul 2021 17:57:28 +0000</pubDate>
                        <description><![CDATA[I’m going in circles.. adjust the nozzle height, I get clicks; adjust the idler screw, I get poor extrusion. Get things good enough for a 75mm square, I get clicks on the next print requirin...]]></description>
                        <content:encoded><![CDATA[<p>I’m going in circles.. adjust the nozzle height, I get clicks; adjust the idler screw, I get poor extrusion. Get things good enough for a 75mm square, I get clicks on the next print requiring more layers, and the cycle continues. (It doesn’t help that one KB article says set the idler screw with filament loaded, and another says set it with filament unloaded. I’ve tried both ways; with filament loaded gave me the better results, I think, but I’ve no idea what a baseline starting point should be now).</p><p>Honestly wishing I had just settled for the “pre-maintenance” prints I was getting, and not touched anything.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>AndrewTerry</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/did-my-first-maintenance-and-ruined-my-printer/#post-468427</guid>
                        <link>https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/did-my-first-maintenance-and-ruined-my-printer/#post-468364</link>
                        <pubDate>Tue, 06 Jul 2021 16:39:05 +0000</pubDate>
                        <description><![CDATA[@andrewterryIt is either that or you are not low enought.  You can save the nozzle with a heatgut, pliers, and acupicture needles.]]></description>
                        <content:encoded><![CDATA[<p>@andrewterry</p><p>It is either that or you are not low enought.  You can save the nozzle with a heatgut, pliers, and acupicture needles.  </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>cwbullet</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/did-my-first-maintenance-and-ruined-my-printer/#post-468364</guid>
                        <link>https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/did-my-first-maintenance-and-ruined-my-printer/#post-468355</link>
                        <pubDate>Tue, 06 Jul 2021 16:33:30 +0000</pubDate>
                        <description><![CDATA[@cwbulletI&#039;m beginning to wonder if do need a new nozzle... I&#039;d be disappointed if I do since I&#039;ve had the printer less than 2 months, but I don&#039;t know what else to try.The last couple of da...]]></description>
                        <content:encoded><![CDATA[<p class="p1"><span class="s1">@cwbullet</span></p><p class="p1"><span class="s1">I'm beginning to wonder if do need a new nozzle... I'd be disappointed if I do since I've had the printer less than 2 months, but I don't know what else to try.</span></p><p class="p1"><span class="s1">The last couple of days, I've been struggling with the dreaded click, which today I traced back to a too-low nozzle height. After much faffing about I printed a lovely, single-sheet 75x75 square, followed by a decent benchy. Happy days, I thought; time to clean up. Followed the process for brushing all the crap from the nozzle, did a cold-pull, and went to do a Prusa logo. </span></p><p class="p1"><span class="s1">Then I noticed every 2cm, no filament would come out. It's quite regular and ends up looking like tartan by the time it finishes the next layer. I did two more cold pulls, which looked ok, then I heated the nozzle to 290 to try and melt whatever gunk may have been left behind.</span></p><p class="p1"><span class="s1">Still no luck. Every 2cm, it looks like the filament isn't being extruded.</span></p><p class="p1"><span class="s1"><a href="https://forum.prusa3d.com/wp-content/uploads/2021/07/74F261C7-E1BC-45E0-AAD6-0F72A02CE6D7.jpeg"><img class="alignnone size-medium wp-image-95794" src="https://forum.prusa3d.com/wp-content/uploads/2021/07/74F261C7-E1BC-45E0-AAD6-0F72A02CE6D7-600x500.jpeg" alt="Tartan texture" width="600" height="500" /></a></span></p><p class="p1"><span class="s1">I don't think my nozzle height is the issue, and I don't think my idler tension is the issue (it doesn't click), but I'm at a loss what to try now.</span></p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/did-my-first-maintenance-and-ruined-my-printer/#post-468355</guid>
                        <link>https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/did-my-first-maintenance-and-ruined-my-printer/#post-467914</link>
                        <pubDate>Mon, 05 Jul 2021 11:21:36 +0000</pubDate>
                        <description><![CDATA[@andrewterryThat found like a possibility.  Sometimes when switching materials, you can leave some material in the nozzle that causes partial clogs.  I remove the nozzle and clean it by hand...]]></description>
                        <content:encoded><![CDATA[<p>@andrewterry</p><p>That found like a possibility.  Sometimes when switching materials, you can leave some material in the nozzle that causes partial clogs.  I remove the nozzle and clean it by hand if purging and cold pulls do not work.  </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/did-my-first-maintenance-and-ruined-my-printer/#post-467914</guid>
                        <link>https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/did-my-first-maintenance-and-ruined-my-printer/#post-467887</link>
                        <pubDate>Mon, 05 Jul 2021 10:18:21 +0000</pubDate>
                        <description><![CDATA[Posted by: @cwbullet Have you thought about replacing the nozzle?I don&#039;t think it needs replacing (I&#039;ve only had it 5 weeks, so i hope it doesn&#039;t! ;) ). I suspect that after my ruining it ti...]]></description>
                        <content:encoded><![CDATA[<blockquote data-userid="77363" data-postid="467329" data-mention="cwbullet"><div class="wpforo-post-quote-author"><strong> Posted by: @cwbullet </strong></div><p>Have you thought about replacing the nozzle?</p></blockquote><p>I don't <em>think</em> it needs replacing (I've only had it 5 weeks, so i hope it doesn't! ;) ). </p><p>I suspect that after my <del>ruining it</del> tinkering with it, I haven't quite found the sweet spot where the gears are grabby enough for both materials - and I'm basing that on that fact that PLA &amp; PETG prints are coming out nicely again.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/did-my-first-maintenance-and-ruined-my-printer/#post-467887</guid>
