Clean outside of nozzle?
infinitemachinery
(@infinitemachinery)
I have had my Mini for a couple of months now and print using it almost daily. I'm noticing a buildup of what looks like burnt plastic on the outside of the nozzle. Do I need to clean this off? If so, how would I do that without damaging anything?
Best Answer by mGoleta:
I use a soft brass wire brush to keep the nozzle clean.  I brush it while the nozzle is hot or still warm.
Napsal : 10/03/2022 3:55 am
mGoleta
(@mgoleta-2)
RE: Clean outside of nozzle?
Napsal : 10/03/2022 6:36 am
languer
(@languer)
I personally use a sock (personal preference); but I also check after every print and if necessary, wipe the nozzle (while still a bit hot) with an IPA wipe to keep it clean. I have printed now for just over 6 months and the nozzle is still pretty clean.
Napsal : 11/03/2022 5:00 am
mGoleta
(@mgoleta-2)
I also use socks on my 3D printers.  There are times that they still end up with a blob of cooked plastic on the nozzle.  When that happens the wire brush is  very effective.
Napsal : 11/03/2022 6:42 am
1 lidem se líbí
LegoYoda
(@legoyoda)
I have been using a wire brush. It seems to work relatively well. It my case, it doesn’t take everything off though.
Napsal : 25/03/2022 4:28 am
be careful, if the wire brush shorts the heater wires to the thermistor wires, with the power on, your controller will be toast!
Napsal : 25/03/2022 7:42 am
gkas
 gkas
(@gkas)
Posted by: @joantabb
Sooooo, that's how I did it!!!! 😥 😥 😥
Napsal : 25/03/2022 11:37 pm
1 lidem se líbí
Ouch!...
If you are good with programming. There is a spare thermistor port on the motherboard.  You could try redirecting the port allocation. And see if the controller is recoverable
 Regards Joan
Napsal : 26/03/2022 1:02 pm
HermannSW
(@hermannsw)
Until now I used pliers to clean below nozzle and on sides if needed.
Only once I used paper tissue, and that was not a good idea, took some time last paper piece got off.
I use a USB borescope camera as nozzle camera in addition to Raspberry scene view camera:
https://forum.prusa3d.com/forum/user-mods-octoprint-enclosures-nozzles/simple-nozzle-camera-borescope-holder-for-prusa-mini/#post-582628
It gives detailed view of nozzle all the time, 640x480, only here scaled down to 320x240 animated .gif:
The animation start shows the problem when early extruded plastic gets in contact with nozzle, and gets lost on first line later. I think of adding 2nd borescope from other side to get 360° view of nozzle.
I have uploaded >20 nozzle camera videos to YouTube lately:
https://m.youtube.com/channel/UCXhm6uSgILX3lrUuaWirZGg/videos
Besides watching nozzle, I get much details of eg. single perimeter 0.4mm thick empty sphere ( initial line shows early extrusion problem as well):
Napsal : 26/03/2022 3:18 pm
