Changed to bearing clips now Y axis fails on check out.
Changed U-bolts to bearing clips, after the change and manually checking the axis moved full range and smoothly, did wizard and the Y axis failed. Did factory reset and ran wizard again, same issue. I have even killed a chicken and sprinkled blood on it and that hasn't helped! Any ideas?
L.
Posted : 10/04/2021 3:02 pm
Topic starter
answered:
RE: Changed to bearing clips now Y axis fails on check out.
Found the problem, the clip on the back side was hitting the Y axis motor.
L.
Posted : 12/04/2021 12:06 am
