Changed to 0.6 nozzle, having issues - gaps in print, crackling noise.
Chuck Stapleton
(@chuck-stapleton)
Membre
I can't figure out why this is happening. Just changed to 0.6 hotend.
First time I did it, there was no gap between the nozzle and the heat block.  So I adjusted the heatbreak down (loosened grip screws, and turned it more into the heat block), and now there is about a 1mm gap between the nozzle and the heat block.
Before and after the heatbreak adjustment, I get prints like the below.  I hear a crackling noise as well while it's printing.  First layer calibration is really bad, but I assume that's because it's hardcoded for a 0.4 nozzle.
Any help is appreciated!
Publié : 10/01/2025 12:07 am
RE: Changed to 0.6 nozzle, having issues - gaps in print, crackling noise.
you need to change the prusa slicer profile to a o.6mm profile at the same time as you change the nozzle.
Have you done this ?
Use the configuration Wizard
Select the 0.6mm nozzle profile,
then in Prusa Slicer, select the new profile
this will set up the nozzle size, the extrusion widths and the layer height options for the 0.6mm nozzle,
I don't have a Mini, but on My Prusa's there is an LCD Menu option to indicate the expected nozzle size...
I recently had a very similar issue because I forgot that I had put a 0.6mm nozzle in My MK3s (been using the Mk3.9 with MMU3 a lot, recently and my  brain is getting old)   if you try to use the 0.4mm nozzle slicer profile with the o.6mm nozzle, the slicer does not output sufficient filament to feed the nozzle's needs...
I hope this helps.
Publié : 10/01/2025 1:17 am
Chuck Stapleton
(@chuck-stapleton)
Membre
I did update the nozzle profile on the printer and I'm using the default 0.6 profile in prusa slicer as well.  So both of those line up.
I didn't have it set on the printer, then when I went to run a job it said I had the wrong nozzle size selected.  So now I know for sure it's set since the 0.6 print jobs don't give me that error.
Any other ideas what could be causing it?
Publié : 10/01/2025 5:35 am
Have you re adjusted Live Z (First Layer Calibration?) since changing the nozzle?
Publié : 10/01/2025 7:47 am
Chuck Stapleton
(@chuck-stapleton)
Membre
I did that as well, even when purging there are pops and you can tell the filament is coming up "thinner" or "broken" when I hear the popping and crackling.
I changed it back to a 0.4 nozzle and it seems to be running ok.  Weird...has to be a flow rate issue?  But I also upped the flow rate while it was printing.
Publié : 10/01/2025 3:45 pm
