BSOD after first layer calibration
I've been using my Original Mini for one month flawlessly.
I recently received a SuperPinda probe to upgrade it. Once replacement done, I followed the first layer calibration procedure, which ran flawlessly until the ending question : "do you want to restart calibration ?" If I answer "no" it goes back to main menu, but if I answer "yes" it goes into BSOD and hotend fan goes full RPM. Only reset or power switch would restart/stop it.
As it first occured after SuperPinda install, I thought this could be linked and reverted back to Minda but it did exactly the same BSOD. Back to SuperPinda then, and if I need to restart first layer calibration I must say NO then go back into dedicated menu to restart it.
RE: BSOD after first layer calibration
The SPINDA has not been available for the Mini for that long. I would turn to the Prusachat with these errors. Possibly the SPINDA is faulty.
