        Bondtech drive for mini+ and saving to eeprom
I bought the bondtech dual drive upgrade when I ordered my mini, but I'm holding off until the mini firmware supports saving the steps/mm setting to eeprom. Apparently this has been a known bug for some time.
Does anyone know if/when this will happen?
                            Opublikowany : 11/01/2021 7:55 pm
                    RE: Bondtech drive for mini+ and saving to eeprom
I believe that is permanent changed from 4.0.5 firmware.
Esteps can be set in slicers start code.
Prusa Mini+ kit. BondTech extruder. FW 5.1.2
Prusa MK3S+ kit. Stock. FW 3.11.0
Prusa MK3S+, used. Stock. FW 3.13.3
                            Opublikowany : 11/01/2021 11:21 pm
Best is to subscribe for updates here: https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/767
                            Opublikowany : 12/01/2021 12:05 am
Just add a start gcode to filament and printer gcode.
Why filament? As a small "failsafe" , once my slicer defaulted to stock settings and it took me a day to figure underextrusion problems.
