Analysed problems with MINDA probe
marcel.mayer
(@marcel-mayer)
Hello Community,
I would like to share my results of an analysis of my Prusa Mini.
Problem description
The bed leveling was fine and I startet a print (PLA 215/60°), which was sucessfull. Then I started a second print, and the first layer was more than 1mm too high. Fixed that with live adjustment. So far so good.
One day later I changed to ASA (260/100°) and the nozzle scratched my steel sheet and destroyed it.
That was driving me crazy and I made so many first level calibrations to fix it, bot nothing helps. For me the probe seems to be fine checked with this manual:
https://help.prusa3d.com/de/article/minda-testing_134024 --> All fine!
Then I went to a friend with a working Prusa Mini to do some tests... Our test setup was an RPI with octoprint and bed level plugin.
Results
First run with my Mini (cold state)
Recv: Bilinear Leveling Grid:
Recv: 0 1 2 3
Recv: 0 +0.093 +0.179 +0.075 -0.075
Recv: 1 +0.041 +0.186 +0.114 +0.028
Recv: 2 -0.062 +0.078 +0.127 +0.118
Recv: 3 -0.104 +0.059 +0.132 +0.108
Second run with my Mini (preheated from first run)
Recv: 0 1 2 3
Recv: 0 +0.141 +0.187 +0.077 -0.059
Recv: 1 +0.059 +0.197 +0.141 +0.090
Recv: 2 +0.057 +0.193 +0.210 +0.203
Recv: 3 +0.040 +0.179 +0.252 +0.267
Third run with bed temp 100°
Recv: 0 1 2 3
Recv: 0 +0.102 +0.190 +0.085 -0.072
Recv: 1 +0.076 +0.259 +0.212 +0.151
Recv: 2 +0.108 +0.283 +0.307 +0.273
Recv: 3 +0.076 +0.243 +0.315 +0.323
First run with another Mini (cold state)
Recv: 0 1 2 3
Recv: 0 +0.725 +0.488 +0.221 -0.032
Recv: 1 +0.811 +0.613 +0.366 +0.058
Recv: 2 +0.813 +0.582 +0.373 +0.112
Recv: 3 +0.799 +0.544 +0.375 +0.107
Second run with the other Mini (preheated from first run)
Recv: 0 1 2 3
Recv: 0 +0.746 +0.467 +0.201 -0.015
Recv: 1 +0.776 +0.554 +0.305 +0.031
Recv: 2 +0.781 +0.524 +0.319 +0.093
Recv: 3 +0.803 +0.531 +0.352 +0.126
Recv: 0 1 2 3
Recv: 0 +0.679 +0.454 +0.208 -0.042
Recv: 1 +0.790 +0.598 +0.368 +0.066
Recv: 2 +0.781 +0.564 +0.368 +0.116
Recv: 3 +0.761 +0.518 +0.351 +0.101
Reason and solution
As you can see, my MINDA probe seems to be more and more confused, then warmer it gets. So it is faulty. My replacement is one it's way for free by Prusa.
This seems to be a problem in general with this sensor and it is definitly not a work around to heat it up before as recommended by many in here.
It's just damaged and needs to be changed by Prusa ...
Napsal : 21/09/2020 7:05 pm
marcel.mayer
(@marcel-mayer)
RE: Analysed problems with MINDA probe
Status update: New MINDA arrived, problems gone!
Napsal : 22/09/2020 3:26 pm
Dimonstar
(@dimonstar)
Great, thanks for reporting back!
I’m waiting for replacement MINDA now as well. Hoping new one will be working correctly.
Napsal : 27/10/2020 6:13 am
spajkej
(@spajkej)
Hello, anyone tried this? Piece of paper glued used hot glue. Im still testing but 10 test prints and success. Z offset perfect all time.
This post was modified před 3 years by spajkej
Napsal : 25/11/2020 7:16 pm
toz se líbí
toz
 toz
(@toz)
Paper against heat - or magnetic interference?
may i give it a try...hmmm
Napsal : 02/01/2021 12:51 pm
spajkej
(@spajkej)
@toz
Well, after 2 months printing almost everyday.... it works. Z offset set to -0.905 since tests started
Napsal : 02/01/2021 5:39 pm
toz se líbí
Posted by: @spajkej
[...] Well, after 2 months printing almost everyday.... it works. Z offset set to -0.905 since tests started
I don't have a Mini to test with, but I love the simplicity of your approach. If heat is the problem, insulate against the heat. It seems SuperPINDA is Prusa's long-term fix, but you've got a possible answer for those who can't or won't upgrade. Now I'm wondering if a reverse approach would have worked for PINDAv1 (which I do have). Build up a little heat mini enclosure around the PINDA to contain the heat.
This feels a bit like finally finding an elegant solution to problems I had on my Apple II computer. Late, but still good to know about.
Napsal : 02/01/2021 8:08 pm
