Scratch Up - For 3d printing
Hello. I starting this topic yeast to have a place to dokument down some information about Scratch up. Its also a learning purposes for me and hopefully other. This topic are maintain over time then i finding some new information i add this to the Topic.
God to know
Segments - at defoult only 24 thats make cirkels in Scratch Up okej. But when you transfer them over to Gcode and print them you can se on the print that cirkels is not perfects. That is what segments is still for. You need to get higher number for this. I have try to find a workaround but no solution found for this at the moment.
Wall thickness - Wall need to have Thickness
Plugins
STL exporter - Link
Solidobjekt2 - Link
Links
Common problems
RE: Scratch Up - For 3d printing
I did a other print and it get OK. But the other after that it get same problem. It Seams IT Jump big to Right.
Item that working to print is small and it seams that when i print X,Y axel printing i get this problem. I did reasently update the frameware to lates one and update the software prusaSlicer 2.2. I dident have any issue before this.
Not working .
BOX
Working
Holder
Hi!
Now i find out my printer have some problems to go to left. It harder for it to go left then right. I trying to find why but dont see anything.
I fixed my problem.. Se my post here!
Here is a video over when i get this problem solved.
https://photos.app.goo.gl/tuR1Nd13PYMVKF8j6
and two image of hot to get it loos.
