PrusaSlicer 2.6.1 will not work on Polaroid 250s
Hi Guys
I am having trouble getting anything newly sliced using 2.6.1 working on my 250s. Old files work fine.
The bed levels, the nozzle heats until the temp is optimised and then nothing happens.
The attached zip contains two sets of Gcode, the one labeled Bike Light bracket works the one labeled test2 does not.
Both files use the same stl file but Test2 was sliced using 2.6.1 and will not work.
I cannot see why. Would love some comments on what is going on here.
Thanks for your help
KK
There are more differences than that. The 2 files use different temperatures, layer height etc. We would need saved project files, saved from Prusa Slicer. File>Save Project as. Then zip up and attach the 3mf files that PS saves. Basically we need the profiles you are using which means the 3mf file(s).
RE: PrusaSlicer 2.6.1 will not work on Polaroid 250s
Hi Guys
The attached zip contains two files the One called Bike Bracket works , the one called Hike Bracket does not.
Looking at the code these are the differences that i have spotted, all at the end of the coding.
Some new and some missing.
I would appreciate any thoughts on which could cause the print to not start. I assuming that the printer reads all code before starting to print.
2.6.1 has added;
wipe_tower_extra_spacing = 100%;
wipe_tower_extruder = 0;
wipe_tower_cone_angle = 0;
support_tree_angle = 40;
support_tree_angle_slow = 25;
support_tree_branch_diameter = 2;
support_tree_branch_diameter_angle = 5;
support_tree_branch_diameter_double_wall = 3;
support_tree_branch_distance = 1; support_tree_tip_diameter = 0.8;
support_tree_top_rate = 15;
overhang_fan_speed_0 = 0; overhang_fan_speed_1 = 0;
overhang_fan_speed_2 = 0; overhang_fan_speed_3 = 0;
overhang_speed_0 = 15;
overhang_speed_1 = 15;
overhang_speed_2 = 20;
overhang_speed_3 = 25;
mmu_segmented_region_interlocking_depth = 0;
filament_multitool_ramming = 0;
filament_multitool_ramming_flow = 10;
filament_multitool_ramming_volume = 10;
extra_perimeters_on_overhangs = ;
enable_dynamic_fan_speeds = 0;
autoemit_temperature_commands = 1
2.6.1 has removed,;
clip_multipart_objects = ;
ensure_vertical_shell_thickness = 0;
filament_minimal_purge_on_wipe_tower =
infill_only_where_needed = 0
3mf files
Hi KK,
Can you share the printer config you used to get the 250s working okay with 2.6?
Bought a new one (hangs head in shame) but too late to be able to source the polaroid prep software and can't give up on it without trying!
Best regards,
Paul
