					                		How to use M907? - General software discussion                                    </title>
                <link>https://forum.prusa3d.com/forum/general-software-discussion/how-to-use-m907/</link>
                <lastBuildDate>Fri, 15 May 2026 08:38:23 +0000</lastBuildDate>
                        <title>How to use M907?</title>
                        <link>https://forum.prusa3d.com/forum/general-software-discussion/how-to-use-m907/#post-710233</link>
                        <pubDate>Tue, 07 May 2024 13:16:16 +0000</pubDate>
                        <description><![CDATA[I currently have a screw extruder fitted to my MK3S, as I am doing tests with a more specialized material. The stepper motor used is already connected to a gearbox to increase the torque, as...]]></description>
                        <content:encoded><![CDATA[<p>I currently have a screw extruder fitted to my MK3S, as I am doing tests with a more specialized material. The stepper motor used is already connected to a gearbox to increase the torque, as the resistance in the extruder would otherwise be too high due to the material. With higher volume flows/faster printing speeds, there are still stepper losses. As the motor can handle up to 1.68A, I would like to increase the current supply. However, the TMC2130 drivers installed can apparently only supply up to 1.2A.</p><p>My questions are:- What is the standard extruder motor current of the MK3S?- Can I use the M907 command in the start Gcode, for example?- How would I have to integrate the M907 command so that it increases the current to 1.1A, for example? (I have seen that you may need to convert the current to a value from 0-63)</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/general-software-discussion/">General software discussion</category>                        <dc:creator>Becker</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/general-software-discussion/how-to-use-m907/#post-710233</guid>
