how to alter hole sizes from a printables download
GreenPea
(@greenpea)
When I print a model from printables but 10 mm holes come out as 9,8 mm holes what do I do wrong? And how can I fix that?
Best Answer by Robin_13:
I also ask if you have done a filament calibration to adjust the "Shrinkage Compensation" for the filament.  I just did some prints and the 7.98 holes are at 7.96-7.90 in size.   Shrinkage compensation is under Advanced.  Just measured a print from today and it was supposed to be 101.5mm and it is 101.55mm long.  Well worth the time and for my usage, one of the best lessons I learned.
I print a 40X40X40 mm cube and do the necessary calculations.  Adjust and print again.
I agree with Joan on running a drill bit through the hole.
Loving the learning curve!
Respondido : 27/06/2025 4:36 pm
For a 0.2mm (2%) error? Run a drill bit through it by hand or dead-slow; power speeds are likely to friction melt it.
Be aware that Printables is no longer a reliable source of files, unless there are pictures of the actual printed article it's best to ignore the entry and even if there are, check the comments before downloading.
Respondido : 27/06/2025 5:44 pm
1 les gusta
Robin_13
(@robin_13)
RE: how to alter hole sizes from a printables download
Respondido : 05/07/2025 3:39 am
